QUESTION ABOUT MODEL VOLUME AROUND PHYSICAL PARTS
Hi, there,
I tried to calculate the capacitance of two parallel materials. I searched the capacitance calculations with Comsol and saw some people model a volume to contain these two materials. So I tried to create a new big block to contain them. However, I cannot change the block material to air. How can I set the model volume to contain these two materials?
It will be appericated if anyone can give me some hints
1 Reply Last Post 22 janv. 2012, 11:51 UTC−5
Posted: 1 decade ago 22 janv. 2012, 11:51 UTC−5
if you change your geometry after a model is fully build (topology change), you need to check all your physics, as often this changes the numbering of the domains and boundaries, and COMSOL cannot always remap them correctly without some "human" help. the new domains might also have to be added to the phyics
Could that be your issue ?
Hi if you change your geometry after a model is fully build (topology change), you need to check all your physics, as often this changes the numbering of the domains and boundaries, and COMSOL cannot always remap them correctly without some "human" help. the new domains might also have to be added to the phyics Could that be your issue ? -- Good luck Ivar
