Fillets in 3D
Hello there,
a question regarding geometry modeling. Suppose I have a 3D geometry, for example a tube with a 90° bifurcation, and suppose I would like to avoid the sharp edges at the bifurcation and add fillets as I would normally do in 3D. How can I perform this operation on a 3D geometry? As far as I know I cannot apply the fillet operation in 3D (if so, why?).
J
3 Replies Last Post 28 avr. 2017, 11:54 UTC+2
Posted: 1 decade ago 17 janv. 2012, 11:03 UTC+1
indeed the internal COMSOL geometry does not have 3D fillets, only 2D fillets, to make cube there is an example discussed (on the forum) try a search
personally I use my external CAD programme for such things
Hi indeed the internal COMSOL geometry does not have 3D fillets, only 2D fillets, to make cube there is an example discussed (on the forum) try a search personally I use my external CAD programme for such things -- Good luck Ivar
Posted: 9 years ago 4 déc. 2015, 16:13 UTC+1
Update on this thread: Nowadays COMSOL does include a direct 3D filleting capability in the Design Module. See www.comsol.com/design-module
Update on this thread: Nowadays COMSOL does include a direct 3D filleting capability in the Design Module. See www.comsol.com/design-module Best, Jeff
Posted: 8 years ago 28 avr. 2017, 11:54 UTC+2
the handy solution I'm using sometime is to build the fillet from scratch:
I make the 3D model, add a prism where the fillet should be, then subtract a cylinder to it, and you get a fillet...
Not very smart or fast, but for simple geometries works.
Giorgio
Hi, the handy solution I'm using sometime is to build the fillet from scratch: I make the 3D model, add a prism where the fillet should be, then subtract a cylinder to it, and you get a fillet... Not very smart or fast, but for simple geometries works. Giorgio
