Help with outplots in Comsol
Hello.
I do not distracting you again but I have another problem.
When I open the surface and add a list of "+"
choose the output somehow.
This is added to the expression that was already in surface box and there is usually nonsense.
Or add a new expression of the surface and when I walk through the editbox mouse so my new expression transcript of the olds..
Thank you very much.
1 Reply Last Post 15 janv. 2012, 12:13 UTC−5
Posted: 1 decade ago 15 janv. 2012, 12:13 UTC−5
Hello
If I catch your right: indeed you have two icons to add COMSOL variable names into plot fields. The gren-red <> icon that adds a new name but first clears the old text; and the green "+" icon that adds the selected COMSOL variable name to the euqation already typed in the input filed. You have also the CNTRL+SPACE combination that proposes the same variable list as the "+"
Hello If I catch your right: indeed you have two icons to add COMSOL variable names into plot fields. The gren-red icon that adds a new name but first clears the old text; and the green "+" icon that adds the selected COMSOL variable name to the euqation already typed in the input filed. You have also the CNTRL+SPACE combination that proposes the same variable list as the "+" -- Good luck Ivar
