Error occurred when try to open Comsol 4.2 with matlab
The error is as follows
Unable to start the JVM
Error occurred during initialization of VM
Could not reserve enough space for object heap
There is not enough memory to start up the java virtual machine
Try quitting other applications or increasing your virtual memory
If you specified memory sizes in a Java.opts file, try reducing them
How to solve this problem?
Thank you!
1 Reply Last Post 15 janv. 2012, 03:40 UTC−5
Posted: 1 decade ago 15 janv. 2012, 03:40 UTC−5
Check the COMSOL KB (kowledge base), I belive there are a few threads about that there with advices
Hi Check the COMSOL KB (kowledge base), I belive there are a few threads about that there with advices -- Good luck Ivar
