Confusion in plotting an interpolation function
Posted 16 mars 2020, 19:38 UTC−4 Parameters, Variables, & Functions Version 5.4 1 Reply
Dear COMSOLers,
In the simplified COMSOL model attached (testCOMSOL.mph) I am using an interpolation function to import a 3D matrix of heat distribution in a cylindrical body, produced and saved as txt by other software ((Edep_Results_mod2.txt)), which is used in the model as an input/boundary condition. The imported data are distributed with the following limits: for x- and y-axis, each, from -2.5 cm to 2.5 cm and for the z-axis from 0 cm to 4 cm, all with 1 cm binning. The problem: when I "plot" the interpolation function, I find that the plot goes in y-axis from -2.5 to 2.5 and in z-axis from 0 to 4, as it must be. On the other hand, in the x-axis it goes from -2 to 2, which is not correct, as it must plot it from (-2.5 to 2.5)! What I am missing here? Or why is this happens?
Regards, Tamer
