Shaker comparison
Hi all,
I would like to compare the displacement of different model at their eigenfrequency. I have done a eigrenfrequency analysis and want to apply thre respective eigenfrequency to the model. As the shaker will have the same displacement but the frequeny will vary, I would like to know if I can use the frequency domain and apply a given displacement to the boundaries clamped to the sahker or if I have to use an other method.
Thanks in advance.
3 Replies Last Post 9 mars 2020, 16:33 UTC−4
Posted: 5 years ago 9 mars 2020, 11:20 UTC−4
Yes, you can use Prescribed Displacement in a Frequency Domain analysis. You will however have to transfer the eigenfrequencies to the input of the study manually. If you are going to do it for a large number of variants, you can consider using a Model Method to automate it.
Note that the response at the natural frequency is completely controlled by the damping, so a good representation of the damping is crucial to get any quantitative results.
See also https://www.comsol.com/blogs/frequency-response-of-mechanical-systems
Henrik Sönnerlind
COMSOL
Yes, you can use Prescribed Displacement in a Frequency Domain analysis. You will however have to transfer the eigenfrequencies to the input of the study manually. If you are going to do it for a large number of variants, you can consider using a Model Method to automate it. Note that the response at the natural frequency is completely controlled by the damping, so a good representation of the damping is crucial to get any quantitative results. See also
Posted: 5 years ago 9 mars 2020, 13:32 UTC−4
Thank you for your answer, I will do it manually as it's just afew model thanks.
Concerning the damping, do I have to input a damping predifned or is it automatically done by the simulation?
Also I started comparing the values from the eigenfrequency model, do you know how the results are defined for the eigenfrequency study?
Thank you very much
Thank you for your answer, I will do it manually as it's just afew model thanks. Concerning the damping, do I have to input a damping predifned or is it automatically done by the simulation? Also I started comparing the values from the eigenfrequency model, do you know how the results are defined for the eigenfrequency study? Thank you very much
Posted: 5 years ago 9 mars 2020, 16:33 UTC−4
You need to enter the appropriate damping. You can find more information about structural damping in
https://www.comsol.com/blogs/damping-in-structural-dynamics-theory-and-sources
and
https://www.comsol.com/blogs/how-to-model-different-types-of-damping-in-comsol-multiphysics
Which results are you referring to? For more information about eigenfrequency analysis, see also
https://www.comsol.com/multiphysics/eigenfrequency-analysis
Henrik Sönnerlind
COMSOL
You need to enter the appropriate damping. You can find more information about structural damping in and > Also I started comparing the values from the eigenfrequency model, do you know how the results are defined for the eigenfrequency study? Which results are you referring to? For more information about eigenfrequency analysis, see also
