How to set upper or lower limit for dependent variables
I want to set a upper limit value for the dependent varible c to promise c<=2. but I type in the input box '2 c', error occurs : 'Unknown model parameter. - Parameter: c'. How to solve the problem?
2 Replies Last Post 3 mars 2020, 10:22 UTC−5
Magnus Ringh COMSOL Employee
Posted: 5 years ago 3 mars 2020, 08:37 UTC−5
The correct syntax here, if the concentration variable comes from Component 1, should be comp1.c 2.
Magnus Ringh, COMSOL
Hi, The correct syntax here, if the concentration variable comes from Component 1, should be `comp1.c 2`. Best regards, Magnus Ringh, COMSOL
Posted: 5 years ago 3 mars 2020, 10:22 UTC−5
Has now the latest version the option for setting limits for a dependent variable? That's interesting.
ZHANG, Pu
School of Physics,
Huazhong University of Science and Technology
>Hi, > >The correct syntax here, if the concentration variable comes from Component 1, should be `comp1.c 2`. > >Best regards, > >Magnus Ringh, COMSOL Has now the latest version the option for setting limits for a dependent variable? That's interesting.
