Keep the units constant inside a "Global 1" in "1D Plot Group"
Dear all,
is there a way to keep the units constant, when creating plots?
Inside a "1D Plot Group" for example I added a "Global" graph.
This graph plots several expressions defined in the table. The unit which I want to plot in this case is [mSv/a].
Whenever I add a new expression at the bottom of the table, Comsol falls back to [W/kg] for ALL expressions inside the table.
These two units are equivalent. Its just, that I want to plot [mSv/a] and it is quite annoying having to change the units for all expressions, everytime I add a new expression to the table.
Is there a way to fix the units for a Plot Group / Graph, so that it only needs to be defined once and is NOT automatically changed again (unless the user defined units are incorrect of course)?
I like the idea that Comsol checks the units and notices mistakes.
But it should not automatically fall back to equivalent units, when the user defined ones are correct.
Thanks a lot and have a nice christmas time,
Juergen
2 Replies Last Post 9 janv. 2012, 12:42 UTC+1
Posted: 1 decade ago 21 déc. 2011, 17:53 UTC+1
good question
learn COMSOL, like COMSOL
good question -- learn COMSOL, like COMSOL
Posted: 1 decade ago 9 janv. 2012, 12:42 UTC+1
I just contacted the support team and filed this issue as a wish for future versions of Comsol.
Juergen
I just contacted the support team and filed this issue as a wish for future versions of Comsol. Best regards, Juergen
