i want to compare the analytic solution with the solution obtained with comsol
Hi , i calculate the analytic solution of the distribution of temperature in a hollow cylinder . I did the simulation in comsol , and i draw the temperature in comsol see figure 1
my problem now i want to calculate the error between the analytic solution and the simulation when i tried to define a function analytic in comsol and use it after , the comsol don't reconize it in the result section see figure 2
please help
thanks
2 Replies Last Post 19 janv. 2020, 04:03 UTC−5
Posted: 5 years ago 18 janv. 2020, 11:37 UTC−5
Adam,
if you defined the function after solving the model you need to update the solution to make it available in the post processing.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Adam, if you defined the function after solving the model you need to update the solution to make it available in the post processing. Cheers Edgar
Posted: 5 years ago 19 janv. 2020, 04:03 UTC−5
thanks , for help it works now ^_^
