Criteria to select the size of the mesh and time steps in a time dependent model.
I'm running a simulation of a stirring tank by using the rotating machinery-laminar flow COMSOL module . The problem includes time dependency , and I am not sure about with size of mesh works better for my model.since I have two parameters such as: size of the mesh and delta time. I have been using the adimensional number:
(u)*(delta t)/(delta x)<0.5
Which means
(velocity)*(delta time)/(minimum size of the mesh)<0.5
Everytime I change the size of the mesh and the time steps in order to guarantee the criterion, I have a different answer in the velocity and pressure distribution.
Does anybody know something about this criterion? Does anybody know how to select the appropriated minimum size of the mesh and delta time for an accurate solution?
Thanks!
4 Replies Last Post 18 févr. 2012, 10:43 UTC−5
Posted: 1 decade ago 20 déc. 2011, 04:11 UTC−5
my way (but I'm mostly in structural and HT) is to first estimate the mesh / time step ratios with formulas as yours, then solve and resolve for a 2x finer mesh, until I'm happy with the results, i.e. < 5-10% change when I double the mesh density.
now mostly you have only a few areas with critical mesh in a complex model, so it's not always required to double the mesh density everywhere, that is too expensive in computing time. mainly I check all my fluxes and see if I correctly estimate all gradients.
You also have the adaptive meshing in the solver settings, all depends on the model and time you have
Hi my way (but I'm mostly in structural and HT) is to first estimate the mesh / time step ratios with formulas as yours, then solve and resolve for a 2x finer mesh, until I'm happy with the results, i.e. < 5-10% change when I double the mesh density. now mostly you have only a few areas with critical mesh in a complex model, so it's not always required to double the mesh density everywhere, that is too expensive in computing time. mainly I check all my fluxes and see if I correctly estimate all gradients. You also have the adaptive meshing in the solver settings, all depends on the model and time you have -- Good luck Ivar
Posted: 1 decade ago 20 déc. 2011, 10:24 UTC−5
Thank you so much!
Do you know the name of this adimensional number? I am looking for more information about mesh in finite elements, but I could not find this specific criterion.
Thank you so much! Do you know the name of this adimensional number? I am looking for more information about mesh in finite elements, but I could not find this specific criterion.
Posted: 1 decade ago 21 déc. 2011, 03:15 UTC−5
the average mesh size is "h" check te doc, its a field (changes with location)
Hi the average mesh size is "h" check te doc, its a field (changes with location) -- Good luck Ivar
Posted: 1 decade ago 18 févr. 2012, 10:43 UTC−5
Hi. I know it is too late. But now I learnt it is called 'Courant-Friedrichs-Lewy (CFL) number.
