Mixture Model Simulation using General Form PDE
Hi folks,
I am using the Mixture Model with K-Epsilon to model solid liquid turbulent flow.
The problem is the overshoot in the turbulence generation of the standard k-epsilon model.
I have pressure values higher than I should.
Since you cannot couple Low Reynolds with the Mixture Model (I am presuming, since I haven't found anything in this matter), I will have to employ General Form PDEs.
I was wondering if anyone has some experience in this matter...
I could use some help, either in the form of existing models or tutorials.
Best Regards,
Rui
2 Replies Last Post 28 mai 2012, 05:11 UTC−4
Hello Rui Silva
Posted: 1 decade ago 27 mai 2012, 03:23 UTC−4
Have you made any headway on this issue?
I'm looking to model a dense, miscible mixture (Euler-Euler is perfect), but k-omega turbulence is essential and not provided in tandem with any of the mixture models.
I was thinking it could be programmed explicity or, as you suggested, coupling the models together, but I have no clue how this could be done in COMSOL.
Cheers,
-M
Hello, Have you made any headway on this issue? I'm looking to model a dense, miscible mixture (Euler-Euler is perfect), but k-omega turbulence is essential and not provided in tandem with any of the mixture models. I was thinking it could be programmed explicity or, as you suggested, coupling the models together, but I have no clue how this could be done in COMSOL. Cheers, -M
Posted: 1 decade ago 28 mai 2012, 05:11 UTC−4
Hello Matt,
I was not successful in coupling the models. And using PDE proved also unsuccessful due to the fact that applying numerical stabilization is very trick in PDE Mode.
So I was left with the option of modifying the mixture model.
I am having some success but still far from complete.
Hope this helps.
Best Regards,
Rui Silva
Hello Matt, I was not successful in coupling the models. And using PDE proved also unsuccessful due to the fact that applying numerical stabilization is very trick in PDE Mode. So I was left with the option of modifying the mixture model. I am having some success but still far from complete. Hope this helps. Best Regards, Rui Silva
