diamagnetic force calculation
Posted 13 déc. 2011, 09:16 UTC−5 Low-Frequency Electromagnetics Version 4.0 4 Replies
I'm working on diamagnetic levitation of a little magnet based on the use of both repulsive effect of diamagnetic material like pyrolitic graphite and attrative effect of permanent magnets.
I'd like to run a simple simulation in which i can estimate the "diamagnetic force" applied by a graphite plate on the permanent magnet.
I measured this force experimentally by bringing the magnet close to the graphite plate and measuring the force with a precision balance.
I did a model with COMSOL 4.0 in which i define the magnet by its magnetization (identified with comsol and a teslameter) and the graphite plate by its relative permeability µr.
My problem is when i used the force calculation to evaluate the force (global evalutation) i find a force value very strong (around 2N) compared to the experimental value (around 0.1mN)
Can someone let me know if i correctly use the force calculation feature?
Thanks in advance.
Stéphane.
Thanks in advance.
Stéphane.
4 Replies Last Post 12 déc. 2012, 07:25 UTC−5
