Creating a geometry from an ASCII file
Hello to everyone:
First of all I apologize because I am a beginner in the use of COMSOL.
I want to create a 2D- axial geommetry. I have a file with the (r,z) coordinates to create the object and I do not know to import this coordinate file into comsol.
Can anyone help me?
Thank you in advance.
2 Replies Last Post 8 janv. 2012, 10:29 UTC−5
Hello Conrado Ferrera
Posted: 1 decade ago 8 janv. 2012, 08:20 UTC−5
have you solved this problem? Recently, I also encounter the similar problem? Could you give me some tips? thanks for your help and guidance.
Best wishes to you and your family.
Hello to everyone:
Can anyone help me?
Hi, have you solved this problem? Recently, I also encounter the similar problem? Could you give me some tips? thanks for your help and guidance. Best wishes to you and your family. [QUOTE] Hello to everyone: First of all I apologize because I am a beginner in the use of COMSOL. I want to create a 2D- axial geommetry. I have a file with the (r,z) coordinates to create the object and I do not know to import this coordinate file into comsol. Can anyone help me? Thank you in advance. [/QUOTE]
Posted: 1 decade ago 8 janv. 2012, 10:29 UTC−5
Hi, I forgot to close this topic. Sorry!. It is quite easy. I was surprised why comsol can not import these kind of data directy. Especially given that is a program that manages geometries. You must follow the following steps:
1 step: Import your file in AutoCAD.
2 step: Import the autocad file in COMSOL
And that is all what you need to do.
Hi, I forgot to close this topic. Sorry!. It is quite easy. I was surprised why comsol can not import these kind of data directy. Especially given that is a program that manages geometries. You must follow the following steps: 1 step: Import your file in AutoCAD. 2 step: Import the autocad file in COMSOL And that is all what you need to do.
