COMSOL with matlab always stop looping
DERA All, I use COMSOL with matlab to run my model with a for-loop (change some parameters every time) . But, when the loop time achieved about 15, it will be ended, and says my computer's memory is not enough. What from where it ends, and after about 15 times loop, it comes again. And, the problem described by COMSOL is bellow:
  Java exception occurred:
  Exception:
  com.comsol.util.exceptions.FlException: The following feature has encountered a problem
  以下特征遇到问题:
  - 特征: 稳态求解器 1 (sol1/s1)
  找不到解。
  执行稀疏矩阵操作时内存不足。
  返回的解不收敛。
  没有返回所有参数步长。
  Stack trace:
  at com.comsol.solver.SolverOperation.execute(SourceFile:284)
  at com.comsol.solver.SolverOperation.addError(SourceFile:442)
  at com.comsol.solver.SolverOperation.execute(SourceFile:292)
  at com.comsol.model.method.SolverSequenceMethod.doRun(SourceFile:2168)
  at com.comsol.model.method.SolverSequenceMethod.doRun(SourceFile:2710)
  at com.comsol.model.dbmodel.SolverSequenceDb.run(SourceFile:186)
  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at     sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.lang.reflect.Method.invoke(Method.java:498)
  at com.comsol.bridge.command.b.a(SourceFile:145)
  at com.comsol.bridge.command.b.run(SourceFile:90)
  at com.comsol.bridge.command.i.execute(SourceFile:45)
  at com.comsol.bridge.command.j.d(SourceFile:711)
  at com.comsol.bridge.command.j.a(SourceFile:699)
  at com.comsol.bridge.command.j$3.a(SourceFile:600)
  at com.comsol.bridge.command.j$3.call(SourceFile:1)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
  at java.lang.Thread.run(Thread.java:748)
Can somebody help me ? Thanks!
2 Replies Last Post 15 nov. 2019, 13:52 UTC+1
Posted: 5 years ago 14 nov. 2019, 12:33 UTC+1
Hi 慧明 汪
There has been a few problems with memory leaks in Comsol 5.4. You should make sure you have installed the latest update: https://www.comsol.com/product-update
If that doesn't solve your problem then there is another solution related to the MUMPS solver here: https://www.comsol.com/support/knowledgebase/1264
Lars Gregersen
Comsol Denmark
Hi 慧明 汪 There has been a few problems with memory leaks in Comsol 5.4. You should make sure you have installed the latest update: https://www.comsol.com/product-update If that doesn't solve your problem then there is another solution related to the MUMPS solver here: https://www.comsol.com/support/knowledgebase/1264
Posted: 5 years ago 15 nov. 2019, 13:52 UTC+1
Thanks! Lars Gregersen! Your suggestion did help me a lot!
