Nagi Elabbasi
Facebook Reality Labs
6 déc. 2011, 10:01 UTC−5
Yes. You need to setup it up as a Fluid-Structure interaction model. You can model the contraction using initial strains.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
19 déc. 2011, 05:23 UTC−5
Thanks Nagi
If I'm correct, your intension was to perform a model for the contracting heart (using strains on elastic body which I will set it's parameters) and to couple the model to a flow model. In fact my case is allot more simple, I'm not interested in a two way coupling. The way the heart contracts is well established I'm more interested in the flow derived from the contraction. Is there a simple way to preset the deformation of my vessel (as a boundary condition) and to perform a model on the derived flow?
Thanks allot
Hemi
Thanks Nagi
Thanks allot
Hemi
Nagi Elabbasi
20 déc. 2011, 08:58 UTC−5
Yes you can couple the fluid flow with moving mesh only (no structure) and use that to displace the fluid boundary.
