Edgar J. Kaiser
Certified Consultant
5 years ago
11 nov. 2019, 11:35 UTC−5
Kate,
this is is probably a visualisation effect. The flux density close to the very thin wire or the line current is by orders of magnitude higher than in the rest of the air domain. So the scaling is not really appropriate to see details of the field.
You can plot log10(mf.normB) to see what I mean. I also saw that you are setting µr for the water domain very close to zero where it should be 1?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Kate,
Cheers
Edgar
5 years ago
11 nov. 2019, 13:45 UTC−5
Updated:
5 years ago
11 nov. 2019, 08:45 UTC−5
Thanks, Edgar! Adding the log10 makes it a lot more clear. I was trying to simulate salt water instead of fresh water, but my university does not own a liscence to the Corrosion module so it is not a built in material. I found that value in a paper, but I will switch it to 1.
Edgar J. Kaiser
5 years ago
12 nov. 2019, 08:32 UTC−5
Hi Kate,
you probably found the magnetic susceptibility which is often used for paramagnetic or diamagnetic materials:
Good luck,
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Kate,
you probably found the magnetic susceptibility which is often used for paramagnetic or diamagnetic materials: \chi = \mu_r - 1
Good luck,
Edgar
