hydraulic head contours in COMSOL
Deal All, I would like to know if it is possible to import ground water hydraulic head contours into a comsol subsurface model and if yes how would that be implemented within the Darcy's Law equations.
Regads, Asal
1 Reply Last Post 31 oct. 2019, 09:08 UTC−4
Posted: 5 years ago 31 oct. 2019, 09:08 UTC−4
Updated: 5 years ago 31 oct. 2019, 05:08 UTC−4
Hello Asal,
If I understand you correctly, you have obtained outside of COMSOL spatially distributed data (for hydraulic head) that you would like to bring into COMSOL to use in a COMSOL simulation.
You can do that by using Interpolation functions. This somewhat older thread explains how.
Jeff Hiller
Hello Asal, If I understand you correctly, you have obtained outside of COMSOL spatially distributed data (for hydraulic head) that you would like to bring into COMSOL to use in a COMSOL simulation. You can do that by using Interpolation functions. [This somewhat older thread](https://www.comsol.com/forum/thread/140432/using-external-file-data-for-heat-generation?last=2017-03-30T15:44:46Z) explains how. Best regards, Jeff
