Particle tracking in turbulent flow help.
Hello readers,
Im quite new with Comsol and I'm trying to get particle tracking to work. I modelled a turbulent flow trough a pipe.
When I create a 2d-plot of Particle tracking with Mass, the trajectory doesnt make sense. It will just go in a straight line from in- to outflow, even if I choose particle mass to be absurd high.
Can anyone help me with this? i attached the file.
Joey
1 Reply Last Post 2 déc. 2011, 11:34 UTC−5
Posted: 1 decade ago 2 déc. 2011, 11:34 UTC−5
These are not directly related but
1-)When you form a union, Do not keep interiour boundaries..You have an inner wall which affects meshing.
2-) Check your particle mass and diameter.
3-)More than 2-3 plots on same page is not much user friendly.
I also had straight lines that even goes thru an obstacle in a channel.
If you are the licensed user, send a message to the tech support.
These are not directly related but 1-)When you form a union, Do not keep interiour boundaries..You have an inner wall which affects meshing. 2-) Check your particle mass and diameter. 3-)More than 2-3 plots on same page is not much user friendly. I also had straight lines that even goes thru an obstacle in a channel. If you are the licensed user, send a message to the tech support.
