error of 'Failed to find consistent initial values'
Dear all,
I have been trying to develop heat transfer (laser pulse model), but After building model when I run the program, COMSOL showing me error ....
Failed to evaluate variable.
Variable: T, Geometry: 1, Boundary: 3
Variable: R, Defined as: ((0.58999999999999997*(T<Ttrans))+(0.65000000000000002*(T>=Ttrans)))
Variable: Gt1, Defined as: ((((1-R)*Pin)*exp((y/da)))/da)
Variable: Gt, Defined as: (((Gt1>=Gt2)*(Gt1-Gt2))*(y<=0))
Variable: mod1.ht.q0 hf1, Defined as: Gt
Expression: d((mod1.ht.q0 hf1*test(mod1.T))*(dvol),{test@0})
I think it is not identifying Temperature 'T' !!!! al other errors are due to that only..
Please kindly help me in this matter.
I have attached .mph file of my model
Thanks in advance & Regards,
Chirag
2 Replies Last Post 26 mars 2013, 00:16 UTC−4
Posted: 1 decade ago 2 déc. 2011, 03:47 UTC−5
the error is because T is not defined on the boundary at start-up (t=0), only in the domain. You can get around by defining a Parameter T = 293.15[K] that will be updated by COMSOL once the solver runs, at least you get rid of your error message
But that is not enough, you have not really done fully your homework: check the diffusivity alpha=k/rho/Cp of Si, you will see that it is of the order of 1E-4[m^2/s] or a diffusivity time constant of about 10 nsec per micron, and your mesh size is about 1 [um] but your pulse length, hence time sampling is in the nsec. You are not resolving your heat flux at all, you need a mesh size I would say 10 times finer, at least in the direct vicinity of the input heat deposit, then further away the heat capacity time constant will slow down the effect and you can use a coarser mesh
You could try with a 16 times boundary layer on the top region, and probably you need to tweak the time solver
Hi the error is because T is not defined on the boundary at start-up (t=0), only in the domain. You can get around by defining a Parameter T = 293.15[K] that will be updated by COMSOL once the solver runs, at least you get rid of your error message But that is not enough, you have not really done fully your homework: check the diffusivity alpha=k/rho/Cp of Si, you will see that it is of the order of 1E-4[m^2/s] or a diffusivity time constant of about 10 nsec per micron, and your mesh size is about 1 [um] but your pulse length, hence time sampling is in the nsec. You are not resolving your heat flux at all, you need a mesh size I would say 10 times finer, at least in the direct vicinity of the input heat deposit, then further away the heat capacity time constant will slow down the effect and you can use a coarser mesh You could try with a 16 times boundary layer on the top region, and probably you need to tweak the time solver -- Good luck Ivar
Posted: 1 decade ago 26 mars 2013, 00:16 UTC−4
I have been having the same error. I am implementing a cahn hilliard equation which is a time dependent fourth order PDE in space. I have one of my dependent variable having no time derivative.So I set it to zero. But I have been getting that error. What do you thin is the problem.
See attached COMSOL file
I have been having the same error. I am implementing a cahn hilliard equation which is a time dependent fourth order PDE in space. I have one of my dependent variable having no time derivative.So I set it to zero. But I have been getting that error. What do you thin is the problem. See attached COMSOL file
