5 years ago
16 oct. 2019, 03:16 UTC−4
Right click your Study node, select "Study Steps-> Other" and insert a "Coil Geometry Analysis" study step. Move this study step above the stationary study step in your model tree.
Should work after that...
5 years ago
17 oct. 2019, 12:07 UTC−4
Updated:
5 years ago
17 oct. 2019, 08:07 UTC−4
Thank you, Now it is working, but I have a new problem. Although the model looks like fine and the simulation goes well to the end, no result is shown up. The current in the close circular coil is set at 1 A but the reult is like a zero current! I download a model from blog that all the seting look similar and while the blog model works fine, my model does not. Do you have any idea?
Thak you
NR
Thak you
5 years ago
21 oct. 2019, 02:13 UTC−4
Difficult to know what the problem might be. If you post your model I can take a look. Might be that the plot you are looking at is looking at the wrong dataset...
