Inserting Function Plots in Application Builder
For a diffusion simulation, I utilized a piecewise function to formulate time-dependent diffusion coefficient based on several other parameters. I am able to plot diffusion coefficient vs time graph on the Piecewise Function Settings interface. Now, I would like to insert this graph in the application builder. Is there a way to do it?
Thanks in advance.
1 Reply Last Post 2 oct. 2019, 13:36 UTC−4
Posted: 5 years ago 2 oct. 2019, 13:36 UTC−4
Ali,
you have the option to generate a plot, which can then be embedded in an application.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Ali, you have the option to generate a plot, which can then be embedded in an application. Cheers Edgar
