27 nov. 2011, 14:54 UTC−5
check the doc, you have many sress elements for different cases
27 nov. 2011, 15:58 UTC−5
Hi Ivar,
I've been reading through the documentation for a while and cannot find anything. Can you explain what you mean by "many stress elements for different cases"?
Thank you,
Theodore
Hi Ivar,
Thank you,
Theodore
Nagi Elabbasi
Facebook Reality Labs
27 nov. 2011, 23:07 UTC−5
The default stress plot is nodal averaged or “Smoothed”. You can change that to element based by setting Smoothing=None in the Quality tab of the result plot. COMSOL also has a more accurate stress recovery algorithm, based on the superconvergent patch recovery technique, which you can activate by selecting Recover=”Within domains”, also in the Quality tab.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
28 nov. 2011, 11:13 UTC−5
Thank you Nagi. That helped tremendously. I knew it was in there somewhere.
-Theodore
-Theodore
