Coupling 2D and 3D models in Comsol
Saheed Ojo Akindeinde
Hi everyone,
Please is there a way of storing a solution from a 2D model as a variable, so that it could be used as an initial condition in a 3D model? Or better still, is there a better way of coupling 2D and 3D models in Comsol. your help/hint would be greatly appreciated.
Thanks.
3 Replies Last Post 7 août 2009, 03:35 UTC−4
Posted: 2 decades ago 20 juil. 2009, 08:33 UTC−4
Hi Saheed,
I think you have to use coupling variables or identity conditions. The choise between them depends on your problem details.
Coupling variables usually work in a more general context.
Hi.
Alessandro
Hi Saheed, I think you have to use coupling variables or identity conditions. The choise between them depends on your problem details. Coupling variables usually work in a more general context. Hi. Alessandro
Posted: 2 decades ago 6 août 2009, 11:30 UTC−4
Hi all,
I am very grateful for the previous suggestions. However, I'm still unable to couple my models. Can someone pls help me outline the steps involved in using Integration coupling variables or direct me to some materials that explains this in details. I simply want to use the result of my 2D models as a boundary condition in the 3D model.
Thanks very much.
Saheed.
Hi all, I am very grateful for the previous suggestions. However, I'm still unable to couple my models. Can someone pls help me outline the steps involved in using Integration coupling variables or direct me to some materials that explains this in details. I simply want to use the result of my 2D models as a boundary condition in the 3D model. Thanks very much. Saheed.
Posted: 2 decades ago 7 août 2009, 03:35 UTC−4
I suggest that you find your way through the documentation or the help files, but as is often tedious as there is quite a lot to read ;)
What I can suggest to ease the search, is that I index all my COMSOL help and doc files and use MS search (or Google search) on them.
There are many cases and examples in there with coupling variables, try them first, this is a powerfull feature, but as any powerfull element it need some training exercice to handle it correctly
Hi I suggest that you find your way through the documentation or the help files, but as is often tedious as there is quite a lot to read ;) What I can suggest to ease the search, is that I index all my COMSOL help and doc files and use MS search (or Google search) on them. There are many cases and examples in there with coupling variables, try them first, this is a powerfull feature, but as any powerfull element it need some training exercice to handle it correctly Good luck Ivar
