Different Result ! Boundary surface and cut-plane
I have a simple T-junction micro-mixer
Geometery: 200*200 micrometer - lenght 2.7 mm https://ibb.co/PgKfwyG
Concentration Contour at outlet boundary using "surface" : https://ibb.co/SKQyK7w
Concentration Contour at outlet boundary using "cut-plan" : https://ibb.co/YPBc6Vx
The problem is that when I use boundary surface for exctracting results I attain some results which are compeletly different from when I use cut-plan at same location. As you see in pictures, concentration countors are not identical in quantities and distribution! What is the problem? and why? would you please recommand a solution?
Sincerely,
1 Reply Last Post 19 août 2019, 09:15 UTC−4
Michael Rembe Certified Consultant
Posted: 6 years ago 19 août 2019, 09:15 UTC−4
Updated: 6 years ago 19 août 2019, 09:05 UTC−4
Hi Khashayar,
I set up a small 3D modell and I observe exactly the same results. No matter if I use a surface- or cut-plane data-set. You can see it using my example model.
I suggest you to set up a small and simple model to test it out.
Best regards Michael
Michael Rembe
Rembe Consulting PartG mbB
www.rembe-consulting.de
Hi Khashayar, I set up a small 3D modell and I observe exactly the same results. No matter if I use a surface- or cut-plane data-set. You can see it using my example model. I suggest you to set up a small and simple model to test it out. Best regards Michael
