Parametric Sweep with Heat Transfer - Initial Values
Posted 24 juil. 2019, 20:20 UTC−4 Heat Transfer & Phase Change, Parameters, Variables, & Functions, Studies & Solvers Version 5.3 0 Replies
Hi all,
I am simulating the heat transfer into a plate with a section of the plate shrinking with time. I would like to perform a parametric sweep that uses defined initial temperature values for the first time-dependent sweep, and then uses the last temperature values from the first sweep as initial values for the second sweep, and so on. How do I specify my COMSOL simulation to use initial values for the first sweep only?
Thank you in advance!
Jan Vincent Carag
-------------------Jan Vincent Carag
Undergraduate Researcher
Artie McFerrin Department of Chemical Engineering
vincentcarag@tamu.edu
Hello Vincent Carag
