Resistance too high using frequency domain
Hi, I am new in Comsol and I am trying to realize a model of a common mode choke. My problem is that during the frequency study in order to calculate the losses of the ferromagnetic core I find a really high resistance of the coils (order of MegaOhm), so I find a really low magnetic field and a really low power. Someone can help me to find the solution? Thanks.
4 Replies Last Post 23 juil. 2019, 12:55 UTC−4
Posted: 6 years ago 22 juil. 2019, 08:56 UTC−4
Updated: 6 years ago 22 juil. 2019, 08:46 UTC−4
It would be better if you posted your file. You may get a better response.
Posted: 6 years ago 23 juil. 2019, 08:26 UTC−4
Updated: 6 years ago 23 juil. 2019, 08:24 UTC−4
Sorry, I send the file with cleaned results to reduce the file size. My goal is to study the model in frequency domain. Thank you for helping me
Posted: 6 years ago 23 juil. 2019, 09:38 UTC−4
Updated: 6 years ago 23 juil. 2019, 09:28 UTC−4
Just looking at it very briefly, on the coil domain setting did you intend for this to be a bundle of wires or single wire wound around a core? Homogenized multiturn is for tiny wire bundles. If that wass your intent then ok. Here is a good example to check out related to this:
https://www.comsol.com/model/multi-turn-coil-winding-around-a-ferromagnet-23641
I would also suggest that you disable the circuit option for now. You can solve this problem without it but activate it later when it model otherwise works. I find it easier to add complexity after the problem solves successfully. That way if something goes wrong you have a better chance of fixing it.
There are other example files to look at on the comsol website. I cannot spend a lot of time on this problem but maybe somebody else can help with more detail.
Just looking at it very briefly, on the coil domain setting did you intend for this to be a bundle of wires or single wire wound around a core? Homogenized multiturn is for tiny wire bundles. If that wass your intent then ok. Here is a good example to check out related to this: https://www.comsol.com/model/multi-turn-coil-winding-around-a-ferromagnet-23641 I would also suggest that you disable the circuit option for now. You can solve this problem without it but activate it later when it model otherwise works. I find it easier to add complexity after the problem solves successfully. That way if something goes wrong you have a better chance of fixing it. There are other example files to look at on the comsol website. I cannot spend a lot of time on this problem but maybe somebody else can help with more detail.
Posted: 6 years ago 23 juil. 2019, 12:55 UTC−4
Updated: 6 years ago 23 juil. 2019, 12:51 UTC−4
Thanks a lot for the help, yes I want to model a single wire around the ferromagnetic core. I think that the problem is caused by the geometry of the coils, so I did a second model using a toroidal geometry for the coils, now the resistance is quite smaller. Thank you again
