Is that possible to group geometries just like group Definitions or parameters?
As I'm working to model a bridge system with all possible details. I got so many geometries (solids, edge, shell, etc) and it's a messy to organize or follow. Is there a way to categorize the geometries so that it can be easily managed?
Ivan
1 Reply Last Post 19 juil. 2019, 17:28 UTC−4
Posted: 5 years ago 19 juil. 2019, 17:28 UTC−4
Updated: 5 years ago 19 juil. 2019, 17:28 UTC−4
Hello Ivan,
For Parameters, the order in which they appear does not play a role, so they can be grouped as you like. Similarly Definitions can be grouped by type. For geometry operations though, the order in which they appear is crucial: the same operations in a different order give you a different object.
With that said, a functionality that can help keep complex geometry branches readable is Geometry Parts, see this blog on that topic.
Jeff Hiller
Hello Ivan, For Parameters, the order in which they appear does not play a role, so they can be grouped as you like. Similarly Definitions can be grouped by type. For geometry operations though, the order in which they appear is crucial: the same operations in a different order give you a different object. With that said, a functionality that can help keep complex geometry branches readable is Geometry Parts, see this [blog on that topic](https://www.comsol.com/blogs/using-geometry-parts-and-part-libraries-in-comsol-multiphysics/). Jeff
