1/r in 2D-axisymmetric volume force: How to deal with it on the axis?
Hi all, I'm simulating ferrohydrodynamics and I'm trying to impose a Volume Force in the Laminar Flow physics. This volume force has a part like this:
((1/r)(d(r(d(A,r))^2,r))+d(d(A,r)d(A,z),z))mu0_const
where "A" is the magnetic scalar potential. When I plot this term, the closest layer to the axis has not been taken into account actually (take a look at the attached image please, the black vertical line is the axis.) How can I prevent this problem? I have instabilities on the axis because of this issue. Thanks
3 Replies Last Post 10 juil. 2019, 17:03 UTC−4
Posted: 6 years ago 10 juil. 2019, 15:41 UTC−4
Updated: 6 years ago 10 juil. 2019, 15:40 UTC−4
Milad,
the 1/r term goes to infinity at the axis (r=0). You need to prevent that some way, maybe by adding a constant>0 in the denominator: 1/(r + const). And you need to be aware that the symmetry does not allow any nonzero radial component at the axis.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Milad, the 1/r term goes to infinity at the axis (r=0). You need to prevent that some way, maybe by adding a constant>0 in the denominator: 1/(r + const). And you need to be aware that the symmetry does not allow any nonzero radial component at the axis. Cheers Edgar
Posted: 6 years ago 10 juil. 2019, 16:25 UTC−4
Updated: 6 years ago 10 juil. 2019, 16:24 UTC−4
Edgar Thanks for your response. This term is a divergence from a field, that's why it makes 1/r. Consider the continuity equation for instance: how this equation is written in 2D-axisymmetric? Does the COMSOL itself prevent 1/0 by adding a constant to its denominator too? Thanks, Milad
Posted: 6 years ago 10 juil. 2019, 17:03 UTC−4
Updated: 6 years ago 10 juil. 2019, 17:03 UTC−4
Comsol isn't modifiying your expression. You need to take care of cases like this by yourself.
Edgar J. Kaiser
www.emphys.com
