Nirmal Paudel
Tribhuvan University/Electrical Engineering
6 years ago
10 juil. 2019, 16:22 UTC−4
Updated:
6 years ago
Why don't you try using the Solid Conductor using the Coil feature to model the solid piece and compute the Lorentz Force?
BR/Nirmal
BR/Nirmal
6 years ago
11 juil. 2019, 01:51 UTC−4
Updated:
6 years ago
11 juil. 2019, 01:49 UTC−4
Dear Nirmal,
Thank you for your reply.
I want to use the Coil future but it cannot be used in time dependent.
Dear Nirmal,
Cesare Tozzo
COMSOL Employee
6 years ago
11 juil. 2019, 10:50 UTC−4
Updated:
6 years ago
11 juil. 2019, 10:49 UTC−4
Are you sure it is a single bulk conductor? If it is a bobbin (or if it is a bulk but you can assume constant resistivity as the pulse is slow... as could seem from your case given a fast look to parameters if it is not a multiturn) you can use multiturn. Transient 3D, current fed works out of the box for multiturn. This will include inductive effect averaged on the coil, but not local skin depth.
Have you already sent the model to support? If not, do it as we could help you as there is a couple of extra tricks for single turn, that you can use for current feeding time domain single turn conductor.
Cite a few.
1) add a voltage feed and se the voltage so to constrint current (in easy cases this is easy and works)
2) mix electric currents and magnetic fields as it is demoed in second part of https://www.comsol.com/model/rotating-machinery-3d-tutorial-10437
3) solution as https://www.comsol.com/model/geometry-optimization-of-a-3d-complex-shaped-coil-for-induction-heating-58051 where the feeding is put via a discontinuity on a "Magnetic Fields No Current" physics
Cesare
Cite a few.
Cesare
6 years ago
12 juil. 2019, 03:38 UTC−4
Updated:
6 years ago
Dear Cesare,
Thank you for your answer, Cesare. I really appreciate your kind support.
My coil shape is like a bobbin. I can use the multiturn in the Coil feature with time dependent but I can't solve it yet.
I'm goin to read those and try a little more. If I can't solve it, I will send the model to support and ask your help.
Thanks!!
Dear Cesare,
Thanks!!
