Moving load with temperature
A mechanical load (line load /edge load) is moving down, over a flat vertical plate. This load also has a very high temperature assosciated with it, Lets assume that heat source also moving along with the mechanical load.
How can we proceed to model it, to find out deformation happens in the Tip, as the heat may also affect the elastic/plastic properties of the plate
0 Replies Last Post 9 juil. 2019, 12:55 UTC−4
Hello Aswin P
