can not get a solution
I am trying to make simulation about inspecting flaw in a plate by coil. My model is attached.
The building of model is no problem. But I can not get a solution. What is the reason?
Could you help me?
Thank you!
2 Replies Last Post 11 nov. 2011, 02:53 UTC−5
Posted: 1 decade ago 10 nov. 2011, 22:00 UTC−5
I changed a little about my model. But this time I got an error like 'out of memory during assembly'.
Attached is the model. Could anyone help me?
Hi, I changed a little about my model. But this time I got an error like 'out of memory during assembly'. Attached is the model. Could anyone help me?
Posted: 1 decade ago 11 nov. 2011, 02:53 UTC−5
Your model solves on my computer, with a peak memory usage of about 4 GB. (I doesn't seem to converge, but that's a different issue.) The error message indicates that you should try to increase the "maximum Java heap size". There's a Knowledge Base article that explains how to do that.
