what's going on?
Posted 10 nov. 2011, 06:39 UTC−5 RF & Microwave Engineering, Geometry, Mesh, Parameters, Variables, & Functions Version 4.2a 11 Replies
I also have tried to make a swept mesh from the surface of an outer sphere to an inner one. It is impossible because Comsol nags that only one surface á domain is allowed. If I define a layer for the outer sphere, it is divided into 8 domains (lower and upper quadrants), and a swept mesh is possible domain by domain.
Making a 2d drawing on the Work Plane and revolving it produces a truncated sphere, but now the outer sphere is again one single domain, and swept mesh is no more possible. I have also tried to use Split and Delete Entity operators in various ways, but have not found a solution. On-line manuals do not help, really.
Are there changes in the drawing operations in version 4.2?
I have no problems subtracting a block from a sphere, even making multiple caps. But I might not use the same shapes as you. But I do not see how to sweep from a sphere to a sphere. Indeed COMSOL cuts parts into their hemisphere/blocks in certain cases to handle curved shapes. Several CAD tools do it like that, but others not ;)
Things have changed, I agree, it took me some days to get used to the new interface, but then I now highly prefer it from the v3.5 one
The geometry sequence worked as expected as soon as I switched to the Parasolid geometry kernel, the one that ships with any of the CAD import modules.
do not forget there are a few geoemtry absolute and relative precision values to be checked/adapted,
these might be involved in your issue.
See the geometry tab
I have a strange error occurring for the mesh based on the geometry that i have built.
The model's big so ive used swept meshes to reduce the no of elements.
I want to keep the no of elements to within 1 million to solve on a 16 GB system.
The default size is 1250 micrometer based on the minumum wavelength/6.
Been struggling with this for quite some time.
Any kind of help would be greatly appreciated.
Ive attached the model in this post.
Mapped1 and Swept 1 are for domain 8 which is one arm of the spiral. This mesh builds successfully.
Mapped2 and Swept 2 for domain 7 which is another arm of the spiral shows an error.
This is strange as both the arms are identical in geometry and in the mesh settings.
Error on inverted element found is
Regards
Glenston
Suggested Content
- KNOWLEDGE BASE Error: Failed to Find a Solution. Returned Solution is Not Converged
- FORUM What to set for "show equations assuming"?
- BLOG How to Get the Most out of Arrow Plots in COMSOL Multiphysics
- KNOWLEDGE BASE Reducing the size of your COMSOL Multiphysics file
- FORUM What is the functions of ec.normJ?
