Thermal Stress in Composite Cylinder
Posted 11 juin 2019, 02:08 UTC−4 Structural & Acoustics, Heat Transfer & Phase Change, Structural Mechanics 0 Replies
I am solving a composite cylinder problem with two different layers. The coupling of linear elastic material 1 and 2 and its simulation is obtained correctly but as soon as I add the thermal conduction effect, it is not showing the correct result. Where could be the problem? How should be the Multi-physics coupling of temperature and thermal expansion done in this case?
Hello Parth Mehta
