Import STL and convert into solid
Hi all,
I have an issue importing my stl. file (this is a model created in Fusion 360) in Comsol 5.4: I'm able to import the file, but then Comsol does not recognize it as a solid, so I cannot perform my simulation.
How can I solve this issue? Thanking you in advance, Best Regards,
Maria
1 Reply Last Post 16 sept. 2019, 14:47 UTC−4
Hello Maria Mochi
Posted: 5 years ago 16 sept. 2019, 14:47 UTC−4
Hi Maria,
Have you tried converting the object to a solid using "Conversions" -> "Convert to Solid" in the geometry node? If you upload the STL, I can try to import it myself.
Nick
Hi Maria, Have you tried converting the object to a solid using "Conversions" -> "Convert to Solid" in the geometry node? If you upload the STL, I can try to import it myself.
