Inclined pipe flow
Hi every one,
I want to model laminar flow in an inclined pipe. The inclination angle is 65 degree. How should I define the flow in such cases?
Thank you so much and your help is highly appreciated.
1 Reply Last Post 4 nov. 2011, 03:30 UTC−4
Posted: 1 decade ago 4 nov. 2011, 03:30 UTC−4
well if you say it's "inclined" you probably mean w.r.t gravity, so ou want to use a body load on your fluid to get the flow going ?
If so a 2D-axi model is not obvious, as the gravity along any angle other than along the axis destroys the 2D-axi symmetry of the model (if yomeone has a good trick here to stay in 2D-axi I'm interested ;)
So I see only 3D, to simulate truely a "pipe", but a first approxiamtion with standard 2D and an "infinetly long pipe" in the out of plane Z direction shoudl also give you useful information
Hi well if you say it's "inclined" you probably mean w.r.t gravity, so ou want to use a body load on your fluid to get the flow going ? If so a 2D-axi model is not obvious, as the gravity along any angle other than along the axis destroys the 2D-axi symmetry of the model (if yomeone has a good trick here to stay in 2D-axi I'm interested ;) So I see only 3D, to simulate truely a "pipe", but a first approxiamtion with standard 2D and an "infinetly long pipe" in the out of plane Z direction shoudl also give you useful information -- Good luck Ivar
