Remeshing
Posted 28 oct. 2011, 01:52 UTC−4 1 Reply
Hi everybody! :)
I'm quite new on COMSOL, and I have to simulate a huge problem: How the gas expand in a gun suppressor?
I am having a lot of trouble regarding the moving bullet, which is very important in the function of the suppressor. So I will probably need to use the Deformed Geometry module to make the bullet travel in it, and I will also need to remesh many times, because the mesh is very modified after a little time.
So, what I have done is: I made the bullet move with a "Prescribed mesh Velocity" on a little time where the mesh is not too much modified, and then I create a new mesh and use it to continue the simulation, but an horrible error occure: "Duplicate Variable Name" T.T
Could anybody tell me how to fixe that? I also tried the Automatic Remeshing, but it does not work at all... same problem.
For now I am just trying to make a circle move in a rectangle with DG and remesh it to learn how the remeshing works, without good results...
Thank you very much for your help. I am particularly stucked...
Remy
Remy
1 Reply Last Post 28 oct. 2011, 03:03 UTC−4
