Lars Gregersen
COMSOL Employee
5 years ago
6 mai 2019, 03:01 UTC−4
Hi Raphael
This sounds strange.
We have seen problems on some combinations of operating systems and CPUs. What operating system are your using? What CPU(s) do you have? How much RAM does you computer have?
Lars Gregersen
Comsol Denmark
Hi Raphael
5 years ago
14 mai 2019, 19:51 UTC−4
Dear Lars,
my operating system is Windows 10. The system has two Intel Xeon CPUs running at 1.7 GHz and 64 GB of RAM.
Any ideas on what might be going on?
Thank you!
Dear Lars,
Thank you!
Lars Gregersen
COMSOL Employee
5 years ago
15 mai 2019, 08:47 UTC−4
We very rarely see problems with some Xeon processors. It may be a conflict with some of the libraries we use.
Try to start Comsol with Matlab with the -np option to adjust the number of threads. E.g. something like this:
comsolmphserver matlab -np 16
You can try with other values. E.g. 24 or 8 and see if that makes a difference.
Lars Gregersen
Comsol Denmark
5 years ago
15 mai 2019, 11:37 UTC−4
Thanks, I will check this but the command is not recognized by my system. Should I run "comsolmphserver -np 16" from command prompt before starting the livelink? Or after starting the livelink?
5 years ago
15 mai 2019, 13:49 UTC−4
Okay, I believe I managed to change the -np option by editing the shortcut to "C:\Program Files\COMSOL\COMSOL54\Multiphysics\bin\win64\comsolmphserver.exe" matlab -np 8 -Dcs.ckl"
And as you expected, this seems to be very important. With -np 8 the solution time is x10 shorter than without -np changes. Very strange but also really good to know! I will play around a bit more and try to find the optimum.
Thanks!
Thanks!
5 years ago
15 mai 2019, 15:49 UTC−4
Updated:
5 years ago
15 mai 2019, 15:50 UTC−4
For your interest, here are the solution times as a function of "-np":
- -np 1: ~15s
- -np 2: ~12s
- -np 3: ~11s
- -np 4: ~10s
- -np 5: ~11s
- -np 6: ~10s
- -np 8: ~11s
- -np 12: ~13s
- -np 16:~75s
- -np 24: ~100s
Is there a way to have the optimal -np for the Livelink set automatically? After all, it seems that the COMSOL GUI somehow finds a better setting than the Livelink?
* -np 1: ~15s
* -np 2: ~12s
* -np 3: ~11s
* -np 4: ~10s
* -np 5: ~11s
* -np 6: ~10s
* -np 8: ~11s
* -np 12: ~13s
* -np 16:~75s
* -np 24: ~100s
