Interpolation function in variable
I want to use a temperature depending interpolation function for the thermal conductivity (Cp)
I made an interpolation graph in the global definitions. (named int1)
There in X-axis it is temperature in degC
and in Y axis it is Cp (J/Kg K)
now I want to use this graph in my heat transfer mode
I think I need to make a variable called Cptemp with a link to int1
but there I get always the following
unknown variable int1
in the heat transfer mode I would change then Cp from material to user defined.
How can this basic problem be solved?
3 Replies Last Post 27 oct. 2011, 02:32 UTC−4
Posted: 1 decade ago 26 oct. 2011, 11:27 UTC−4
if you define a function/operator and you want to call it you mustadd the variable such as int1(T[1/degC]). Now as T is a field depending on x,y,z you need to define this for a formula having a domain or a boundary or an edge or a point as selected items.
Note use rather T in [K], the default, or take at least care with the units, ther are new functionalities for unit definitions in the function in v4.2a
Hi if you define a function/operator and you want to call it you mustadd the variable such as int1(T[1/degC]). Now as T is a field depending on x,y,z you need to define this for a formula having a domain or a boundary or an edge or a point as selected items. Note use rather T in [K], the default, or take at least care with the units, ther are new functionalities for unit definitions in the function in v4.2a -- Good luck Ivar
Posted: 1 decade ago 27 oct. 2011, 01:59 UTC−4
Ivar,
thanks a lot for solving this basic problem which is occuring often because we have lot of data in function of temperature.
Ivar, thanks a lot for solving this basic problem which is occuring often because we have lot of data in function of temperature.
Posted: 1 decade ago 27 oct. 2011, 02:32 UTC−4
there are several essential and basic issues I had, when beginning with comsol, particularly how to understand variables, and really to catch that everything (most "variables" ) are in fact depending on x,y,z. and that most GUI fields apply to element volums of size *dx*dy*dz therefore the "density dimensions on most default field units
Hi there are several essential and basic issues I had, when beginning with comsol, particularly how to understand variables, and really to catch that everything (most "variables" ) are in fact depending on x,y,z. and that most GUI fields apply to element volums of size *dx*dy*dz therefore the "density dimensions on most default field units -- Good luck Ivar
