Henrik Sönnerlind
COMSOL Employee
5 years ago
15 avr. 2019, 11:19 UTC−4
Updated:
5 years ago
There is no built-in such coupling. You can however set it up manually. What you need is
- A pressure load on the structural side
- A normal accceleration on the acoustics side
- Extrusion coupling operators moving the variables from one side to another.
In order to see how to set up the loads, you can take a look at
https://www.comsol.com/model/vibrations-of-a-disk-backed-by-an-air-filled-cylinder-188
One of the variants there uses a manual coupling, so you can see which nodes to use. However, you cannot just pick up the variables as in the example, since they live on different boundaries. You have to type them in yourself, using expressions like genext1(acpr.pt). Look in Equation View for the Acoustic-Structure Boundary multiphysics coupling to find the names of the appropriate variables.
Henrik
Henrik Sönnerlind
COMSOL
1. A pressure load on the structural side
2. A normal accceleration on the acoustics side
3. Extrusion coupling operators moving the variables from one side to another.
One of the variants there uses a manual coupling, so you can see which nodes to use. However, you cannot just pick up the variables as in the example, since they live on different boundaries. You have to type them in yourself, using expressions like *genext1(acpr.pt)*. Look in **Equation View** for the **Acoustic-Structure Boundary** multiphysics coupling to find the names of the appropriate variables.
Henrik
