Arc Length and Coordinate Transformation
I have a 1D Shear Rate vs arc length plot around a full circular post. Arc Length starts from 0 to pi()*D where D is the diameter of the post. I wanted to convert arc length to angle with an equation. I used ds1 , ds per manual and posts on here but it did not work.. What is the expression term for arc length that equals to Pi()*D?
(I am using Excel as a temporary solution but this required excel data export, calculation and sort data. So I wrote an excel macro but still this is extra work )
My other question is Can I place a coordinate system in the center of this circular post and get 2D stress data in polar coordinates.Expressions allow me x, y z only. Coordinate transformation menus are not very clear.
I appreciate your help.
E.Turk
2 Replies Last Post 22 nov. 2011, 13:41 UTC−5
Posted: 1 decade ago 20 oct. 2011, 02:09 UTC−4
in 2D, 2D-axi and 1D the arc length variable for an existing edge is "s" and runs from 0 to 1 along the edge "arrow" direction. Note that if your arc of circle is split your s is also split and not always running round in the same direction. In 3D it's more complicated as it has 3 components.
another way is tu use a variable such as r=sqrt((x-x0)^2+(y-y0)^2). Pls do not forget which frame you refer to and use the xyz and XYZ correctly, see the doc ;)
Hi in 2D, 2D-axi and 1D the arc length variable for an existing edge is "s" and runs from 0 to 1 along the edge "arrow" direction. Note that if your arc of circle is split your s is also split and not always running round in the same direction. In 3D it's more complicated as it has 3 components. another way is tu use a variable such as r=sqrt((x-x0)^2+(y-y0)^2). Pls do not forget which frame you refer to and use the xyz and XYZ correctly, see the doc ;) -- Good luck Ivar
Posted: 1 decade ago 22 nov. 2011, 13:41 UTC−5
Thank you.
Thank you.
