Mtrl_lib for TiO2
the Mtrl_lib is not up to date how do I change/rewrite the data on that file?
2 Replies Last Post 27 déc. 2009, 23:08 UTC−5
Posted: 2 decades ago 27 déc. 2009, 04:47 UTC−5
material data is often changing, with new discoveries, measurements and publications, etc.
Personally I do never change the COMSOL material library data, but I add any new/corrected entry into my personal data library, that I keep from version to version. And at each new version I cross check with the new material data library to remove tfrom mine tose that have been updated/corrected.
Now pls do not forget to mail to "support" (and perhaps here too) about any error found and provide them with references to new material data you believe needs correction/updates, otherwise us others out here might still use oldish data and get wrong results ;)
I.e. you need bulk sintered alpha Silicon Carbid data for large high tech structures, such as optics and optomechanics, to update the material library, then try here:
www.boostec.com/SiCTypicalCharacteristics.pdf
I have notice too that in the optical domain, there is quite a lot of material data missing i.e. for thin film analysis.
I beleive that such data can only come through a common efforts, from all users
Have a nice day
Hi material data is often changing, with new discoveries, measurements and publications, etc. Personally I do never change the COMSOL material library data, but I add any new/corrected entry into my personal data library, that I keep from version to version. And at each new version I cross check with the new material data library to remove tfrom mine tose that have been updated/corrected. Now pls do not forget to mail to "support" (and perhaps here too) about any error found and provide them with references to new material data you believe needs correction/updates, otherwise us others out here might still use oldish data and get wrong results ;) I.e. you need bulk sintered alpha Silicon Carbid data for large high tech structures, such as optics and optomechanics, to update the material library, then try here: http://www.boostec.com/SiCTypicalCharacteristics.pdf I have notice too that in the optical domain, there is quite a lot of material data missing i.e. for thin film analysis. I beleive that such data can only come through a common efforts, from all users Have a nice day Ivar
Posted: 2 decades ago 27 déc. 2009, 23:08 UTC−5
Morning Ivar
thank you very much for the reply.
I added a new library with my updated data. it woreks..
thank you very much
Guy
Morning Ivar thank you very much for the reply. I added a new library with my updated data. it woreks.. thank you very much Guy
