initialize timestep and Temperature to use prev()
Hello, to calculate the current cooling rate I use the formula (T-prev(T,1))/(t-prev(t,1)). However. In the first step I cannot use the prev() command, as there are no values before the first step. Can I somehow initialize these values? Or can I even calculate the cooling rate more elegant? Kind regards, Christian
5 Replies Last Post 5 avr. 2019, 02:57 UTC−4
Posted: 6 years ago 2 avr. 2019, 07:37 UTC−4
More elegant is to use the built in time derivative of the temperature, 'Tt'.
Henrik
Henrik Sönnerlind
COMSOL
Hi, More elegant is to use the built in time derivative of the temperature, 'Tt'. Regards, Henrik
Posted: 6 years ago 3 avr. 2019, 08:30 UTC−4
thank you for your answer. But I still have a similar problem: Variable Tt cannot be evaluated. The problem is in the first step I think. I do have the starting temperature T at t=0 for all points in x,y,z. The problem was with the older method using prev() that I could not evaluate dT/dt at the first point as I do not have enough Data. I think this time I have a similar problem. If necessarily could even provide an initial value for Tt, if I would know where to assign the initial value of Tt.
Currently I do have an analytic function defined in the components and I just used Tt for the cooling rate.
Hi, thank you for your answer. But I still have a similar problem: Variable Tt cannot be evaluated. The problem is in the first step I think. I do have the starting temperature T at t=0 for all points in x,y,z. The problem was with the older method using prev() that I could not evaluate dT/dt at the first point as I do not have enough Data. I think this time I have a similar problem. If necessarily could even provide an initial value for Tt, if I would know where to assign the initial value of Tt. Currently I do have an analytic function defined in the components and I just used Tt for the cooling rate. Kind regards, Christian
Posted: 6 years ago 3 avr. 2019, 10:53 UTC−4
Hi Christian,
What study type (and settings) are you using?
Henrik
Henrik Sönnerlind
COMSOL
Hi Christian, What study type (and settings) are you using? Regards, Henrik
Posted: 6 years ago 3 avr. 2019, 11:05 UTC−4
Hi Henrik,
My Study looks like this: I am using an optimization and as Step 1 I use a Time Dependent Study Step. In the Solver Configurations the optimization solver is also time dependent. The error appears in the optimization solver (as I use my function as an Objective for my optimization). Kind regards, Christian
Hi Henrik, My Study looks like this: I am using an optimization and as Step 1 I use a Time Dependent Study Step. In the Solver Configurations the optimization solver is also time dependent. The error appears in the optimization solver (as I use my function as an Objective for my optimization). Kind regards, Christian
Posted: 6 years ago 5 avr. 2019, 02:57 UTC−4
Hi Christian,
I think you should either contact support, or upload a simplified version of your model here.
Henrik
Henrik Sönnerlind
COMSOL
Hi Christian, I think you should either contact support, or upload a simplified version of your model here. Regards, Henrik
