ECM (Electro Chemical Machining)
if any one is working ecm process in 3d geomerty. please help me because i am also working on ecm
2 Replies Last Post 26 mars 2019, 06:19 UTC−4
Posted: 6 years ago 25 mars 2019, 11:27 UTC−4
Hello Mule,
The following couple of links could be good starting points for you:
This blog includes a link to a 2D model.
This paper from the COMSOL Conference is in 3D.
Jeff Hiller
Hello Mule, The following couple of links could be good starting points for you: This [blog](https://www.comsol.com/blogs/pulsed-electrochemical-machining-a-multiphysics-model) includes a link to a 2D model. This [paper](https://www.comsol.it/paper/accelerated-electrochemical-machining-tool-design-52272) from the COMSOL Conference is in 3D. Best regards, Jeff
Posted: 6 years ago 26 mars 2019, 06:19 UTC−4
Thank you Mr.Jeff Hiller for your reply.
I have seen those papers before and i did a similar problem.Here ,my question is ''how to rotate the tool electrode in 3d geametry''
Thanks and regards
Thank you Mr.Jeff Hiller for your reply. I have seen those papers before and i did a similar problem.Here ,my question is ''how to rotate the tool electrode in 3d geametry'' Thanks and regards
