How can I do a point analysis on a line between two points?
I am new to comsol and programing. I am modeling a parallel plate flow chamber in 2D. Basically, I have a rectangle with an inlet, an outlet and a reactive surface. I am modeling receptor-ligand binding with flow. I want to know the concentration of my species on points along the reactive surface. How can I do this?
Thanks you,
Nisha
1 Reply Last Post 11 oct. 2011, 16:19 UTC−4
Posted: 1 decade ago 11 oct. 2011, 16:19 UTC−4
have you tried to make a line plot, select the line of interest, variable concentration, then define the x axis as "X (or Y or Z) and not the default "s" line length index
You can add several line plots to a 1D plot node
PS it works better in thenewver releases of Comsol ;)
Hi have you tried to make a line plot, select the line of interest, variable concentration, then define the x axis as "X (or Y or Z) and not the default "s" line length index You can add several line plots to a 1D plot node PS it works better in thenewver releases of Comsol ;) -- Good luck Ivar
