Tabulate global evaluations from parametric sweeps
I'd like to calculate elements of a capacitance matrix between three terminal conductors. I can do this with a parametric sweep and global evaluations very successfully (es.C11, es.C12 etc.). Ultimately, however, I would like to calculate these capacitance matrix elements as a function of the distance of one of the conductors. I can also attain these results in discrete steps using a parametric sweep and global evaluations. However, the problem arises when I try to calculate these elements in very small discrete steps over a long distance. In theory I could do this, but I would have to manually create a new global evaluation for every capacitance element and every discrete step.
I would like to find some way to automate this problem. I need a sizable array of points and I am using 3D geometry so can't afford to do this manually each time I want to evaluate.
-Elliot
0 Replies Last Post 10 oct. 2011, 17:29 UTC−4
Hello Elliot Fuller
