Surface Current Density Comsol 4.4
I would like to know what is the difference between induced Current Density (emw.Jix), Surface Current Density (emw.Jsx), and Current Density (emw.Jx).
Thanks in advance, Jose Santos.
1 Reply Last Post 16 mars 2019, 14:24 UTC−4
Posted: 6 years ago 16 mars 2019, 14:24 UTC−4
I'll tackle two of those. emw.Jx is the x component of the volume current density in the x-direction, so it is in units of A/m^2. Use it for materials with non-zero and non-infinite conductivity. emw.Jsx is the x component of the surface current density, so it is in units of A/m. I use if most often to look at surface currents on perfect conductors (PECs), but I think (I haven't checked, but you could check fairly easily) you could also use it on a surface that was specified with an impedance boundary condition.
