meshing 3D coil
Posted 3 oct. 2011, 16:16 UTC−4 1 Reply
I am attempting to mesh a complicated 3D coil. At first I thought I would need to mesh the entire object to obtain the fields after applying a current, but I believe it will suffice for my purposes if I just make the volume wires into lines. Is there an easy way to take a 3D coil and turn it into lines (no surface area) so that I can easily put a current through it? My file is too big to attach, so if you would like to take a look at it, email me.
Jason
Jason
1 Reply Last Post 4 oct. 2011, 01:22 UTC−4
