How to suppress a subdomain in V 4.x?
Dear all,
in V3.5a it was possible to suppress a subdomain - how can I do that in V4.2?
I need this to have a closer look at results, especially when they differ a lot between subdomains (f.e. high and low stresses in different materials).
Thanks for your help,
Birgit Palm
3 Replies Last Post 28 sept. 2011, 08:41 UTC+2
Posted: 1 decade ago 21 sept. 2011, 13:03 UTC+2
Hi!
In "Results" the button for hiding disappears (why?). But you can go to "Model 1" for example, select your domains and hide them. Then go back to "Results"...
Ralf
Hi! In "Results" the button for hiding disappears (why?). But you can go to "Model 1" for example, select your domains and hide them. Then go back to "Results"... Ralf
Posted: 1 decade ago 21 sept. 2011, 18:23 UTC+2
it's in the additional sub-nodes of the Definition and View, but then you need to be sure your results plot is pointing to hte view with the hiding (by default it's automatic = the current active "view" = the one with the green frame around the icon
Hi it's in the additional sub-nodes of the Definition and View, but then you need to be sure your results plot is pointing to hte view with the hiding (by default it's automatic = the current active "view" = the one with the green frame around the icon -- Good luck Ivar
Posted: 1 decade ago 28 sept. 2011, 08:41 UTC+2
thanks to you two - I found it (and I think I have seen it before, but forgot about it).
Greetings,
Birgit
Hi, thanks to you two - I found it (and I think I have seen it before, but forgot about it). Greetings, Birgit
