Running a parametric sweep using parametric inputs from another study
Marcus Collier-Wright
Hello. In my project I am simulating a resonant cavity with a microwave input. My goal is to simulate the resonant electric field for a variety of geometries.
My current simulation process consists of two study steps for a given geometry. Study 1 is an eigenfrequency study to determine the resonant frequency of the geometry.
Study 2 is a frequency domain study with a microwave input. I set the frequency of the microwave input as the eigenfrequency calculated in study 1.
I can run a parametric sweep on study 1, changing one parameter (e.g. cavity height) to output a set of eigenfrequencies for each parameter value. I then want to run study 2 sweeping the same parameter but for each value, I want the input frequency to be the eigenfrequency for that particular geometry configuration.
This is straightforward to do manually but I'm having trouble automating it. I'd like to be able to define a parameter sweep of one parameter, and have COMSOL calculate the eigenfrequency and then the frequency domain solution for each configuration automatically.
Any help would be greatly appreciated.
0 Replies Last Post 7 janv. 2019, 10:41 UTC−5
Hello Marcus Collier-Wright
