How to see the results without having the initial geometry lines ?
hi ,
I have simulated a problem in COMSOL V4.2 and I want to plot the results somehow without having the initial geometry lines in my plot.
For example I want to plot the contours of the pressure but I do not want the geometry lines to be seen in this plot. Is there any way to somehow hide the geometry lines for post processing ?
best
3 Replies Last Post 24 juil. 2012, 14:24 UTC−4
Posted: 1 decade ago 10 sept. 2011, 05:23 UTC−4
there is a tick mark in the main 2D/3D plot menu node I believe (I do not have access to COMSOL just now)
Hi there is a tick mark in the main 2D/3D plot menu node I believe (I do not have access to COMSOL just now) -- Good luck Ivar
Posted: 1 decade ago 10 sept. 2011, 08:56 UTC−4
thanks Ivar for your quick response, I found it as you said.
best
thanks Ivar for your quick response, I found it as you said. best
Posted: 1 decade ago 24 juil. 2012, 14:24 UTC−4
Where can I find that option in COMSOL version 4.3?
Where can I find that option in COMSOL version 4.3? Thanks
